Re: Volvo AQ125 problems
Hi romeo, welcome to iboats!!<br /><br />You will need a multi-meter and perform some simple tests.<br /><br />Compared to electronic, points ignition is relatively simple to diagnose. Just replacing the parts will not always bring the beast back to life. <br /><br />Some things to check - when new, points have a protective coating, give them a clean with a piece of cardboard soaked in carbyclean or brakeclean (something that evaporates and leaves no residue). <br /><br />Double check the gap and then finely tune the gap by using a dwell meter, make sure that your feeler gauge is spotlessly clean.<br /><br />Test for voltage at the '+' terminal of the coil (ignition 'on'). With the points open, you should have battery voltage (12v). With the points closed, you should see 7 - 9 volts.<br /><br />Aldo
