Volvo AQ120B Float setting
Hitech
Does anyone know what the carb float should be set at on a Solex 44 PHN 3 carb? The kit came with a "ruler", but no documentation. I could measure the existing setting (I haven't taken it apart yet), but I'm trying to fix a problem, so I don't really want to do that.
Hitech
Re: Volvo AQ120B Float setting
Thanks, but that is for the 125 and it uses the PAI carb (down draft). You don't happen to have that for the 120B do you?
Don S
I would have swore your post said 125, must have stared at the sun too long.
I do have it, but give me a few minutes and I will get it set up so you can download it.
Hitech
Thanks Don, you da man.
And it must have just been the impaired digit. ;)
