Can someone help me with the location of the two diodes in the Volvo fuel pump circuit. One is in the "light" lead from the alternator that supplies 12 vdc to the fuel pump relay while the engine is running and the other is in the starter solenoid circuit that provides 12vdc to the relay while the engine is cranking.
Where is the ground point for the fuel pump and relay primary circuit? I have an intermitant problem with the fuel pump shutting down while the engine is running. Unless I miss my guess this points to the circuit from the "light" terminal of the alternator, a marginal fuel pump relay or bad ground.
The fuel pump itself is apparently OK as I have jumped out the relay and the problem disappeared.
Any help appreciated, Thanks.
