Volvo 501b - poor top end
jim.bresee
Howdy folks...
The patient is a 1993 Volvo 501b.
The symptoms: runs great between 2-3k rpm. Starts fine very time. At 3600 rpm, it develops a hard stumble and won't go any higher. It has a slight stumble when pushing the boat onto a plane at full throttle.
Here's the history:
Motor overheated last year and was replaced with a new long block. Boat was out of commission much of the summer, and didn't go above 3k due to break in.
This summer:
1. New plugs
2. New Plug wires
3. New cap/rotor
4. new coil (the old coil was leaking oil out of the top- boiling over?).
6. New fuel pump - the oil has gas in it, and the pump was seeping into the bottom of the engine.
7. Timing has been checked, and advance appears to be working - but I don't have a timing light that has the advance feature to verify.
8. The carb was rebuilt due to a hot start issue last year -the guy who rebuilt it said he was not real comfortable with the carb. Last year, if you shut the engine down after running a few minutes it would flood. Rebuild seems to have addressed the issues.
I had a mechanic play with the boat for 3 weeks. The new fuel pump reduced the rough running, but it's still not able to get over 3600 rpm.
The mechanic suggests the valves may need adjusting, or the carb needs to be replaced with a new edelbrock.
What do you guys think? Any other ideas on what I can check?
Thanks,
Jim
jim.bresee
Re: Volvo 501b - poor top end
Don,
Thanks for the reply.
1. I'm ok on oil level
2. Flame arrestor is clean
I have not checked restriction or check valve issues on the fuel line. I think I'll go after that next.
Thanks again for the post.
Jim
f_inscreenname
I would do two things. Hook up the fuel pump to a new fuel tank (like they use for outboards) and get a different carb to try on it. I used to have a Holly do that. Drove me nuts. I rebuilt it twice (one time was over the winter so I took as long as it took to do every tiny little thing perfect). First test drive it did the same thing. Went home and threw it on the concrete as hard as I could to make sure I would never waist my time and money again with it. A bad carb is a bad carb and I have learned a long time ago there ain't no fixin a bad carb.
