Re: Volvo 5.7GSI with DP-SM Drive 2001
I will add a bit more info. VP 5.0 liter ina 20 ft Chris Craft bowrider. The boat has about 110 hrs on it. I bought it about 4 monthes ago from orginal owner. I use it alot, he never did, as it had 40 hrs when I bought it. He was a bit of an idiot and ran it trimed up to put it on the trailer when I sea trailed it. The price was right so I bought itanyhow, figuing U joints might be in my future. At about 50 hrs got a goofy noise and vibration when turning. Gimble or U joints for sure. Plus I wanted to pull drive and do service. The gimble bearing had worked out of the transom housing. U Joints seemed 100% OK. I measured the bore and the housing was OK, so I installed a new bearing and checked alimanent,it was OK. The bearing was a nice fit into housing , so I think that is good and fine. I don't have an OEM alinment tool, but a homemade machined one for a Mercruiser I used to own and I thing the diameters are the same. Everything was all happy for about 60 hrs. I changed lube and next time out after boat had been run a couple hours I get this goofy noise in neutral only. Turning and trim do nothing, so I think gimble bearing and U Joints are not an issue. I know the shift linkage where the rod meets the horz. plate, has some wear and slop. I plan to add the stainless steel washers I have heard about this weekend to take some of the slop out. I have a factory service manual and am very mechincal. I am a mechanical engineer for a living. I will look into the shift shoe shimming. Is that an exturnal operation of must upper unit be disassembled? Thanks very much for your help. I am new to this forum board thing, pretty darn cool that there are people helpfull around like you all. Thanks
