Volvo 5.7GSI "98" model <br />280 hp. Fuel injected <br />READ BELOW UPDATE FIXED<br /><br />VOLVO engine does not achive WOT....<br />What it does...<br />It lacks power will only build to 3100 rpm fighting to get on plane.. Running like motor is weak.but,runs smooth,starts fine,idles smooth,just bogs under load.<br /><br />replaced oxygen sensor in throttle body and now starts and idles fine but, lacking power.<br />Any suggestions.<br />I have found somewhere to hook her up to a computer but, that is 70.00 bucks thought I would try here for suggestions.<br />Thanks,<br /> <br />I will be on here off and on until I hear something.<br /><br /><br /> UPDATE as of 6- 22-04<br />ok had it put on computer No codes[ figures]<br />what we know know.<br />COMMENTS NEEDED<br />1. motor getting to much fuel <br />2. Spark plugs were fouled from that[putting in new]<br />3. Thats all they can find but, still looking<br />Anyone know why it would be dumping to much fuel? <br />My brain is on overload<br />I do know it is electrical cause the fuel pump is controlled by the computer {brain}<br />I was grasping at straws hoping a code would show.<br />Thanks I really appreciate this.<br />***********************************************<br />Boat Fixed Running properly WOT<br /> <br />Found out yesterday 6-25-04<br />Saw mechanics Found flapper valve in Y pipe come loose and fell down into the pipe restricting exhaust flow also weak coil that was installed from the first shop.<br />Water tested today 6-26 with mechanic ran properly.<br />WOT is 4250 with no problem planing<br />END of my delimma
