recently bought a 1994 23' cuddy cabin with a 5.7 volvo gi. the boat accelerates and planes fine unless you push the throttle wide open, then it bogs........whether you are just taking off or at speed. it will also only turn about 4000 RPM and if I try to give it any more throttle once it reaches 4000, it will bog and lose speed until I back the throttle off a bit. Changed the spin-on fuel filter and ran some inj. cleaner through it with no relief. wasn't a big deal until I had the boat loaded with 6 adults and I need WOT to plane out....took forever since I could only give it 80% throttle......engine only has 150 hours on it. does this sound like a fuel prob. or an ignition prob?
