We are considering purchase of a new 2008 Larson with a 5.0GL and SX drive.
When we took it for a test drive, we noticed a whining noise when in-gear at idle. The noise did not existing when in neutral at idle. We couldn't tell if the noise was still there when on plane--if it was still there, it was drown out by all the other usual noises.
The salesman blew it off as "normal", but also admitted he was more familiar with inboards.
Someone else I talked to said there should be LESS noise when it gear at idle due to a slightly lower RPM
Your thoughts/opinions/is the noise a problem?
Thanks in advance for your comments
Stan
Stan
