History: I have a Four Winns 200 year 2000. It has a Penta 5.0 GL (Charcoal) engine. The boat has been sitting for a couple of years. Boat is on trailer with water hose hooked up during testing described below.
Issue: I finally got the motor "running". With running I mean firing on all cylinders (distributor replacement). Now on to the next issue - there seem to be a lack of oil pressure and an oil leak....
When I fire it up the alarm beep keeps beeping and the little oil can indicator is blinking -not good. I obviously turned off immediately. I wanna say the alarm was not beeping continuously, only on higher RPM?s strange enough. (Is the alarm on the engine supposed to sound? I only heard the alarm from boat instrument panel)
I noticed that milky oil is leaking out in the harmonic balancer / front of crankshaft area, not sure exactly where yet. As mentioned the oil is white. When I check the dip stick the oil looks fine, no water. Looking down the oil filler cap I see some white in the oil, until now I figured it was just from sitting for so long in Florida?s humidity. Now with the milky oil leak from a different location I am not so sure anymore? I probably had the engine running for about 15 seconds between my 3-4 attempts before I gave up on getting oil pressure. In that time a nice streak of oil was made on the bilge right below the harmonic balancer. I would guestimate the amount of oil to about a tablespoon. One of the belt driven devices seem to be causing some resistance. When the engine was rev?d a bit they squealed. It could obviously be the generator but I figured I would mention it since it could be water pump related. I should point out that these belts are probably fairly old.
Where is the most likely place for the leak?
Any theories why the leak is a mix of water and oil?
I realize that I am most likely in for a surgery in the balancer area. Just hoping I can do what I need with the engine in boat. I am also worried that I may have TWO issues. The water in oil may have a different cause than the leak.
Any tips are much appreciated!!
Thanks,
Henrik
Thanks,
Henrik
