Volvo 4.3 Power Steering problem
started a power steering whine on Saturday, checked resevoir it was low
no problem filled it
Sunday same thing fluid in bilge
checked resevoir/pump no leaks, 2 connections on back-tight ,no visible leaks
both lines from resevoir snake off behind the engine which is where
i am assuming my problem is
Im also assuming that one or both of those lines go to a piston???(that turns the drive??)
I thought my god i cant even see back there, how will i ever find it to fix it
any suggestions or schematic of where those lines go and how they connect
also aside from the annoying whining of the steering , am i damaging if i operate with a leak
Thanks
Thanks
