I Just purchased a 1972 Bayliner with a 307 inboard and Volvo 280 Outdrive. It runs fine for about 20 mins at 160 degrees. Then the temp spikes to about 200-220 degrees and I have to shut it down. When this happens, I can keep my hand on the starboard manifold riser but the port riser is cooking?? I have had both risers removed and cleaned. The water flows good through both risers. I disconnected the water supply to the port riser and cranked it over and there was water up to that point (pulsating??). Am I correct that because the heat seems to be on only one side that the problem would be in the manifold/riser assy?? <br />Any help/advice would be appreciated
