Volvo 3.0L 135HP No Start
jmdevera
I am having a hard time getting my 1997 Larson started from the winter. I have done all the normal things with carb cleaner and start fluid and it cranks all day but no start. I have changed out all the plugs (re-gapped), distributor, rotator, and coil (yes i did test). I also check the fuel pump and the stream into the carb. Thinking it was the gas I took the fuel line into a fresh can for fuel and made sure all the "old" fuel was out of the lines.
It sounds like 1 and 2 were trying to fire to I check all the plugs again. 1 and 2 look like they have been sparking and have oil on them. 3 and 4 have very little oil and look like they have NOT been sparking.
I am running out of options! :confused:
Can anyone shed some light???
Don S
Re: Volvo 3.0L 135HP No Start
Do you have spark when the engine is cranking?
jmdevera
I am pretty sure I am getting spark on 1 and 2. I have not tested this yet, I am just using my ears.
Ayuh,... It takes Fuel, Fire, Compression,+ All at the right Time...
You're missing atleast 1 of 'em...
You'll discover Which 1 by Testing each 1...
Bart Sr.
What is the status of your kill switch??
jmdevera
my kill switch is in and appears active. however did pull the kill cord and noticed it had no affect on the attempted start. I have never test the kill switch before so i am not sure if it disconnects all power or not. Is anyone else familiar?
jmdevera
I checked all plugs with a tester and all have spark.
