Hi all. I am new to this forum. I've read as much as I can but nothing specific to this symptom. Any help from the members here would be appreciated. On a cold start, our engine will stall if I put it in Fwd or Rev at idle. The only way to make it work is to wait until the engine has warmed up to curising temp of approx 175 degrees. It doesn't matter what temp rage it's in while warming up, if it's not at cruse temp, it stalls the moment it is placed in gear at idle. Or stalls as soon as the engine is loaded at idle. Believe me, it's a long 15 minute wait before I can get it into gear without stalling. The boat is 2008, Fourwinns H-180 boat with a Volvo Penta 3.0 liter engine. The engine has a 2 barrel Holley carb. It has a total 21 hrs on which is not much. It ran fine when new. Last year, the dealer rebuilt the carb under warrany. However, now that we have used it for it's second season, it has been degrading over time and getting worse. Other info that might be useful is the idle speed in gear is 1000 RPM (under load) In neutal (no load) it's approx 1400 RPM Which seems a bit high.
