degerb1170
- Aug 31, 2010
- 6
Hi Guys:
I have a 290 outdrive that will not trim down hydraulically from the full up position when it is in hard contact with the rubber upstop. The motor runs in either direction but the outdrive will not move down unless I bleed a small amount of fluid from the hyd upline and let the outdrive drop manually less than a 1/4". I retighten the hose, then the outdrive will work normally until the next time it is raised to the full up position. Any suggestions? A new pump assy?
degerb1170
degerb1170
