volvo 285 seals
Finhead
Trying to replace seal behind shifter on outdrive. Looks like right behind eccentric piston. Do I just have to remove that to get at old seal or do I need to remove bearing housing as well? Is there anything to be cautious about?
Also thinking about replacing two seals behind prop on propshaft. Can I just remove bearing housing or do I have to pull entire propshaft?
You guys are great. Thanks in advance for any help/wisdom.
Don S
Re: volvo 285 seals
Here is a link to the OEM manual. It explains exactly how to do both jobs.
