Brian Wilbur
- Sep 1, 2002
- 2
I have a 1984 Bayliner, Volvo Penta AQ125A, with 270 outdrive. It's a freshwater boat. The tilt mechanism worked fine early this season; now all of a sudden it doesn't work. Electric motor runs fine, worm and drive gears mesh and turn, but spindle doesn't move. The sterndrive doesn't even move a fraction when the mechanism is engaged. I haven't removed the tilt mechanism from the mounting collar yet - it appears it will require some force to do so. Before I do damage, I want to be sure I'm headed in the right direction. My guess at this point is the spindle has corroded in place. My thanks in advance for any advice you might have.
