thanks don but it seems i cant open your drawing for some reason.When you try to raise the drive, does the lockdown release? If it is staying locked, you may have to adjust the thrust sleeve that contacts the tilt mechanism (B) in the drawing below.
Could also be the mechanism is slipping and will not have the power to lift it.
