Volvo 225D Timing
jastacey
I just got around to installing a Petronix conversion kit and my question is; the timing mark on the harmonic balancer/pulley, is it a line/grove ( mine is a groove ) and I set the timing to 8 degrees before top dead center ),
as per the Volvo shop manual. My other question is; when I set the idle, should I have the boat in the water or just hooked up to the garden hose O.K.?
Don S
Re: Volvo 225D Timing
You should be able to adjust the idle mixture and speed on muffs. If that's not satisfactory when you put the boat in the water, readjust it.
