volvo 151 sputters and dies
gino45
This morning it was dying repeatedly while on my way out fishing so I turned around and went in. Then in the washdown area it ran fine even when I revved it up.<br /><br />I have already:<br />replaced points and rotor<br />replaced fuel filter<br />replaced vacuum line<br /><br />Any suggestions as to what to do next?
akriverrat
Re: volvo 151 sputters and dies
what vacumn line? did you have water in your fuel filter? was the water choppy? that could stir up water in tank or be causing loose wire somewhere to make and break. fought the water and slime problem this spring and loose wire on ignition switch several years ago. it could be a multitude of things and really need more details.
gino45
Water wasn't choppy or anything like that. At first I thought it was fuel filter--replaced. Then I did the points and rotor--no change. Finally found the loose vacuum? from fuel pump to carb, and I thought sure that would solve the problem; however, it did not. I don't think it's a loose wire problem, and I don't know what to do next.
Fouled Plug
Ensign
Am I correct in assuming it was conking out in gear, under load and then revved fine in the washdown area in nuetral?
akriverrat
that line is there in case the pump diaphram starts leaking the gas will go into the carb and not in the bilge. very worthwhile fix but probably no bearing on your problem unless there was gas in it.
