Re: Volvo 125aqa overheat
Aldo,thanks for the reply and suggestions to fix my overheating problem.In addition to the work imentioned i have also had some pitting on the head filled planed and replaced the head gasket.This past week i reset the head bolt torque to spec 66 ft lb, but I'am not sure I did it right. I didn't first loosen the bolts and then reset the torque,I just checked to see if they were still at 66ftlb, should I have done it differantly. IN all, todate Ihave cleaned the heat exchanger core [just as you would an auto radiator,replaced the exhust manifold,replaced the thermostat,the sea water impeller ,the engin water pump and all the seals and the engin coolent holding tank cap.Something Ididn't mention is I take take the sea water with a through the hull port,not through the outdrive.This is my second try to respond to you,I'am not sure if the first message ever made it,I hope I did this right Once agan thanks for the help and if you can please sent more about the heatexchanger combustion detector test I'am not all sure what that is or how it's done or who can do it for me. BEST regards Salmoneer
