volvo 125a trouble
tatoodan
I have an 83 bayliner with a 125a and a 270 outdrive . the problem is that when the rpms get to about 3000 the motor cuts out and sputters . I have allready replaced the entire ignition and starting systems,cleaned the carb and replaced the gas .I also put a new fuel pump in.the motor runs fine at low rpm and in neutral. it only acts up in gear and has run perfect in previus years. please help I am stuck:confused:
Don S
Re: volvo 125a trouble
List of possible causes of low WOT.
I would be seriously looking at item 3
Engine Won't Reach Operating RPM. Check
  • Fuel condition. Type and Octane possibly old fuel
  • Propeller pitch or diameter, damaged blades
  • Restricted fuel pickup tube or anti siphon valve Fuel System Test
  • Crankcase oil volume, high oil level can cause aerated oil and lifter collapse
  • Marine growth on hull and outdrive
  • Wrong gear ratio in outdrive
  • Restricted carburetor air intake (clogged flame arrestor)
  • Restricted exhaust system (broken exhaust shutters/flappers) in engine transom shield or drive
  • Poor cylinder compression Compression Test
  • Carburetor defective, or wrong type.
  • Fuel pump pressure and vacuum
  • Boat overloaded, improperly loaded, or improperly trimmed.
  • Engine Overheating
  • Engine timing and ignition system operation
  • Remote control cables and linkage for proper travel to open throttle plates fully.
tatoodan
I have allready checked the anti siphon valve, pickup tube and lines . the only things I havent checked are the compression and the exhaust shutter. I know there used to be a rubber flap on the outdrive down by the prop this has been gone for a long time. is that it or is there another one inside that I am missing ?
somone else told me to check that but I can't find any reference to that in my manual :confused:
Don S
But did you actually put a gauge on there and check. A loose connection on a fitting or hose will allow it to suck air, and can (and will) cause the problem. With the gauge and clear hose you will be able to know for sure.
That is the only one.
tatoodan
I have not done the test ,I have checked every thing several times .I will preform the test and I will check the compression today and post the results. thank you for your help.
