Reading several post on batteries, I understand that you need the higher range of volts for starting the motor.
Do amps play a part here? Never really saw it mentioned.
If I have a battery that has 12.6 volt, any idea how many amps I should be reading? Or would this be dependent on the "Cold Cranking Amps" of the battery?
