volts needed to start 150 Vmax
colayn
Can anybody tell me what is the minamul volts needed to start a 99 150 Vmax if all else is good on the battery?
I am running a lot of electronics on my start battery and want to set a low volts alarm on my sonar.
Have set down to 11volt alarm but it goes lower than that while cranking.
Thanks,
Paul
99yam40
Re: volts needed to start 150 Vmax
This is why most run a house battery for their electronics and start battery only for starting
Starting motor draws voltage down too much and resets or alarms electronics
On some motors if the voltage drops too far the motor will not spark properly make sure your battery and all connections and cables are in good shape
Capt Ken
You need a least 9.5 volts at the starter when cranking.
colayn
Thanks guys.
I would like to have separate battery, but just not enough room in this bass boat. Already have 3
My new sonar is power hungry and until I get some history just wanted to set a low volts alarm to be sure I can still crank her up. I will set it a 10.0 v and see if it alarms out when cranking
Thanks again,
Paul
99yam40
If Start battery voltage drops to 10V or even 11V while just running electronics, when you hit starter I very much doubt that the starter will crank motor properly.
Probably be best to tap into trolling batteries with electronics as you do not want to not be able to crank motor out on water
You can measure battery voltage while cranking motor to see how low it drops while cranking
Capt Ken
Yep, if your battery voltage drops to 10, you have a dead battery and won't start anything.
stylesabu
Master Chief Petty Officer
amps are more importanr than volts. have you given any thought to a lawn mover or motorcycle battery they're about half the size, run your electronics off this. then install battery isolator to charge it off the alt, but won't allow it to discharge other battery
