Hello fellas, I've got a 1996 Mariner 115HP (OG348734) and had indications of a bad Voltage regulator/rectifier (intermittent high rpms and high voltage reading). I purchased a new VRR from a Merc parts express dealer. The SN on the box he gave me shows 883072T but the part in the box has 892115-001 stamped on it. I've done some searching and found most places that the part that replaces the 815279-3(original) is in fact the 883072-T or even a newer 854515. However I've been unable to find any VRR with a serial number 892115-001..which is what I received from the dealer. Can anyone tell me if it is even the correct part. It fails the SCR and one diode static checks per the SELOC manual. Also, does it matter which yellow wire (two of them with same male connector) is connected to its mate or are they the same? Thanks for any inputs.
