Voltage Drop
00harleymike
I have a 2005 fuel injected Volvo 4.3 gxi e. Issue started today where I would try to start the engine, turn key and fuel pump would come on but as soon as I tried to start the volt meter would drop to zero from 13v. Changed battery and same results. Any thoughts? 20
gbeltran
You have a short or a bad battery cable or connection at the battery. When you say changed the battery you do mean swapped out for a new one I trust.
Ayuh,..... Welcome Aboard,...... Odds are you've got corroded wires in the system,.....
Start at the battery terminals, 'n clean 'em to shiny clean metal, both ends of both cables,.....
Lou C
Check wiring but you also might have a seized or internally shorted starter...be careful...that can generate a lot of heat...any smoking or hot metal smells when you try to start?
