voltage at coil
Thumbtack
I have a mercruiser standard ignition (points) with a coil that is getting extremely hot. With ignition on i have 12.5 volts at the battery and about 10.5 volts at positive wire at coil, i would expect it to be around 9 volts with the resistor wire, is this 10.5 too much?
If this is a problem do they make a coil that doesn't need a resistor, or do they make a resistor i could put inline with the wire?
Chris1956
Re: voltage at coil
Thumb, The voltage is already lower at the coil, than the battery. Why do you want to lower it further? The lower voltage helps protect the points from burning, but degrades the spark.
You can get a ballast resister or a coil with a built in resistor. The questions is does your ignition system have the correct components in it now? if so, why do you wnat to change them out?
JustJason
Re: voltage at coil
are you leaving the key on when the engine is not running? if so, that's a no no with points.
gdombroski
Re: voltage at coil
Coils are made to operate a 12 volts. The resistor is to lower it to protect points. May be time to replace coil.
Thumbtack
Re: voltage at coil
Thanks for the replies, i replaced the coil and everything seems fiie now. I don't leave the ignition on when the engiie isn't running because i know that would burn the points. The coil was getting super hot to touch when engine was running. And the reason i was wondering about the resistor is because i know someone was playing around down there. But i thought the voltage at the coil was to be at 9volts but i guess not.
Thanks agaii
JustJason
Re: voltage at coil
if you wanted to double check, and you still have the old coil. sand off some of the paint on the coil houseing and put your meter on resistance. Check for resistance between the primary, secondary, and the high tension out to the coil housing, it should read infinity. If it does not then you have a coil thats shorted internally..... (may or may not work, it's possible for the coil to past the test when cold, but fail when hot)
