Re: volt meter
Run a wire from the I Terminal on your key switch, to the I post on your gauge. Ground the gauge to the G post.<br /><br />If your key switch isnt labeled, splice into the SOLID PURPLE wire on your engines wiring harness and run that to your gauge.
