I have the following engine:
Engine - 2000 model year - 4012033328 5.7 gsi pefs
The engine turns over but will not start.
Ran perfect last Monday when I docked it.
Fuel Pump appears to be working properly.
Just put on a brand new fuel filter and filled the fuel filter up with new fuel after I remove the new filter to ensure the fuel pump was pumping fuel. Removed and added fresh fuel to try to eliminate a fuel related issue.
Again-- turns over strong just will not start and ran and started perfectly the last time I used it (less then a week sitting)
Would appreciate any advice or check list.
Thanks a ton,
Kevin
Thanks a ton,
Kevin
