I have seen a few similar posts but none the exact same so I figured Id ask. I have a 2003 Volvo 3.0 SX drive. When the engine is running in neutral or in gear I can hear a knocking noise inside the out drive. It gets worse when I turn the wheel hard to either side. I have checked the bellow and there is no water in there (I was able to unscrew it and pull it back enough to peek inside w/o removing the drive), but about 2 years ago I had the bellows and gimbal replaced b/c it was leaking. I have also greased the gimbal bearing from the fitting on the outside. I?m am thinking it could be the u-joints but want some other opinions before removing the out drive.
