Hello All,<br /><br />I have a '97 model Vmax 150 trp. My surfing so far tells me that the 97 model motor actually puts out 189hp (at the props I think) - so it is very nearly a Vmax 200 with a different leg.<br /><br />I use the boat for waterskiing and am finding it drops power sometimes under load. I can run at top speed all day and it doesn't worry it. If I do a fair bit of barefooting, after a while it will drop about 400rpm. It doesn't run rough - it is like a cylinder drops off. I don't know if my boat has an overheat alarm or if it is overheating.<br /><br />I ran with the cowl off trying to diagnose the problem and was able to tow two barefooters for ages at full throttle (50mph with a bit of trim). It didn't fault. A week later, I had a lot of people in the boat, one footer, cowl on and it did its old trick.<br /><br />A while back when I was having this problem, we found the fuel bulb was going soft. I have now put in an inline fuel pump and got rid of a couple of small but in the way kinks in the fuel hose. I have also replaced all the fuel hose except the bit from the filter into the motor, put a fuel strainer (for big chunks) in before the fuel pump and replaced the fuel filter. It is a full water seperating CAV type. I run Australian Premium Unleaded Petrol (95-96RON the supplier web site says)<br /><br />I'm finding this to be a big hassle. Any suggestions please? I just don't know if it is electrical, fuel, overheat or whatever<br /><br />Maybe answers to the following questions might help:<br /><br />* How can I tell if there is some kind of overheat alarm<br />* How can I test the alarm<br />* Should I avoid the premium fuel (I switched to it after a bad batch of standard gummed up my carbies really badly)<br />* Is there some kind of cutout that could do this<br />* Any ideas on what could give these kinds of symptoms?<br /><br />Thanks<br /><br />Greg
