You guys are right, this could get addicting, lol.
After sitting in a shed for 8+ years, cooking in triple digit summer heat, this 'obsolete' M9.8A fired right up! There is gas sludge in the fuel bowl so I expected the carb to be gummed up too but with gravity fed fuel directly to the carb, it started and ran ok.
Water was coming out of the back of the column, and out of a small hole in the base of the engine right behind the rear mounting bolt.
Is that a normal telltale hole or a drain for water that's not supposed to be in the motor base? (second pic)
After only a few minutes, both the water streams stopped, so I assume the impeller died?
Shut it down before it could get too hot.
Does the mostly outside corrosion indicate salt water use?
Information on the A version of these 9.8s is almost nil but I did get a genuine Parts List book. Haven't found a service manual anywhere, only for M9.8B or C models.
How much difference is there in the A or B models?
Personally, being new to outboards, I really like this design: Easily accessible simple dirt bike style carb, fuel bowl & pump, coils, etc.. I love accessible common sense engineering on machinery. Not sure about the bottom end, but the top end couldn't be easier to work on.
This short shaft fits the boat much better than the '59 Evinrude 5.5 LS and has more power, easier to work on, not to mention 10 to 20 years newer. Guessing it must have needle bearings instead of bushings, etc...
Not having a B model to compare it with, I don't know how much of the A carried over or was changed.
Just exactly how rare and obsolete is this A model?
As someone stated in the other thread, I must be able to retrofit some other impeller.
Is that fuel connector obsolete or is it the same as other Tohatsu or Nissan, Honda, or?
All suggestions and input are greatly appreciated.
Thanks, Dave
Thanks, Dave
