Re: Viking 6 hp outboard motor
Eaton's made Vikings, so these are Canadian only engines. Naturally, ol' Tim wasn't hammering them together out back, so these are rebadged Chryslers at that point. Model 64801 is a 1968 6hp two cylinder engine. A manual that covers similair year Chryslers will be good for yours too. Someone sent me this from an old Viking owner's manual:<br /><br />Horsepower 6 Brake HP at 4500 RPM<br />Engine two cycle two cylinder, alternate firing<br />Bore and stroke 2 x 1 11/16<br />Displacement 10.6 Cu. In.<br />Carburetor Float feed<br />Connecting rod Forged Nickel Steel Uncased needle bearings at crankshaft. Cased needle bearings at piston pin<br />Crankshaft Forged Nickel Steel. Cased upper Main bearing. Bronze lower main, centre main and thrust bearings<br />Propeller Aluminum alloy 7 ½ Dia. X 7 ½ pitch, Right hand rotation<br />Cooling Water cooled positive displacement type water pump<br />Transom height 15<br />Weight 55 Lbs.<br />Fuel mixture 24:1 1/3 pint SAE outboard engine oil to 1 gallon of regular gas 85 octane<br /> Avoid Premium gasolines with 95 octane and antiknock additives<br />Recommended Operating range 4000 5000 RPM
