Video of my engine acting up. Please help! Tried everything!
197935hpjohnson
http://www.youtube.com/watch?v=S8x-SExDuW8&feature=plcp Here is what its doing.
Things ive done/checked are as follows:
1: Compression 120psi on both cylinders
2: New plugs
3: Disassembled, cleaned, inspected and reassembled carburetor. (It was perfect inside)
4: New fuel lines
5: Verified timing is opening all the way and carburetor is opening fully under full throttle.
6: New fuel, tanks
7:Disassembled fuel pump, inspected and reassembled (Everything looked good)
8: Checked all wiring for corrosion/loose connections
9 Verified both cylinders are firing (But have not done spark gap test)
I just dont know what else to do, please if someone could help me i would be GREATLY appreciated.... It just simply has NO power and wont rev under a load. However, if put muffs on it, or in a test tank it will rev out like its supposed to. Just not under a load.
P.S. Pumping the primer bulb does not make a difference, so i "think" ive ruled out a bad fuel pump.
boobie
Re: Video of my engine acting up. Please help! Tried everything!
You should stick to one post as you'll get better answers and it's less confusing !!
