4.3GL PEFS
4110199022
3869053
I was winterizing the boat this past weeekend and I have noticed all summer that my motor seems to vibrate more than I remember at idle. While waiting for it to warm up I noticed the impeller pump housing vibrating like crazy, when I put my hand on it I could really feel it. Is this the symptom of a bad bearing? Would it cause the motor to vibrate? There are no leaks and cooling works fine. I have read that you have to replace the whole assembly for about $200-$300. Should I replace the pump in the spring? Motor is a 2000 model year.
4110199022
3869053
