Hello to All
Getting around to buying/installing a VHF on our 2008 Bayliner 195 Discovery. I'm looking for comments/suggestions on what I propose.
The components:
ICOM M422 Submersible DSC VHF Radio
ICOM Command Mic II
Morad VHF-156FG Fiberglass VHF 6dB gain whip antenna
West Marine Stainless Steel Rail Mount - with Lever
The installation:
Mount the M422 underneath the dash. This due to the lack of space on the dash.
Use the Command Mic II hung on or near the starboard side of the dash to for control/use of the M422.
Use the rail mount to affix the antenna to the bimini frame close to the bimini top. The antenna weighs only 2.5 lbs so it would seem to pose no significant strain on that structure and would position the antenna as high as possible on the boat. Haven't measured exactly, but would probably put the antenna ~ 12' above the waterline. Run the coax down the bimini frame (plastic ties),along and under the gunwale to the radio.
I like the Morad as its 1.25 to 1 SWR is better than Shakespeare's 1:50 to 1 and it's lighter and appears better suited for a 19' runabout. The levered rail mount would allow the antenna to stow on the gunwale with the bimini down or to allow use of the antenna (diminished ht/range) with the bimini down.
Any comments/suggestions appreciated.
Thanks
Explorer1
The components:
ICOM Command Mic II
The installation:
Thanks
Explorer1
