Re: VHF handheld radio
"should this suffice" depends on "for what." it iwll be fine for talking to boats nearby; it is not sufficient for emergency.
I've used the handhelds a lot both around the harbor and at the hunt club (where we have VHF base stations, on on a 75' tower). In perfect perfect conditions you may stretch 5 miles but not likely. Batteries get weak; line of sight gets blocked (each antenna has to "see" the other). I can hear traffic from many miles away but can't respond. A coast guard base about 10 miles away won'ty answer, but they are like that sometimes.
So consider them like a walkie talkie for talking to people you can see at a distance, and for weather. Anything more, for a boat your size, get a mounted 20w with a good antenna.
3 watt is too weak. Get a marine submersible with 5 watts. But salt air gets in even the watertight ones.
I've been using Uniden brand through the years and am somewhat satisfied, but I believe Icom is the better brand. Costs more. And they like to change the configurations around so you can't replace batteries easily--although Uniden sells refurbished radios for close to the cost of a battery. Use the akaline battery pack for back-up to the rechargeable one.
Also, be sure the antenna is vertical to be effective. On my small boats, I mounted the plastic battery charger base on the console so I can let the radio ride there, safe, high and upright (you don't need the base to charge).
