Re: VHF-GPS connection
Not always easy because each unit will have a different means to hook up. On the Icom, you probably have an RCA connector and on the GPS you may have just wires. You may have to wire up an RCA connector to the correct GPS wires and plug that into the RCA connector on the Icom.
Both manuals will show what wires are the RXD+(NMEA+) and RXD-(NMEA-). Often, the RXD-(NMEA-) is just ground.
