Re: VHF engine motor noise
Resolving noise problems can be challenging. First, remove the antenna and see if it is still there. If so, then you are sure it is induced through the power line and not the antenna.<br /><br />If it is power related, make sure the ground is solid and tied down well. Second thing would be to get a noise filter from radio shack or car stereo shops. <br /><br />If the above does not work, run the power cable temporarily away from the other cables (outside of the conduit) to see if the noise is induced "capacitively". In other words, the noise is being picked up by the location of the wire and not through the powerline itself.<br /><br />Note that reducing the noise at the source is much more effective than filtering it after the fact. So you may want to make sure your alternator is running well. BTW, make sure the alternator is the cause by rev'ing the engine. If the pitch does not increase, the it is not the alternator.<br /><br />Anyway, hopefully you get some ideas out of this. Dealing with noise like this can be quite difficult at times. Ultimately, you may need to replace your alternator or the radio to resolve this.<br /><br />Amir
