deerhuntre
- Apr 26, 2007
- 186
I'm installing a new antenna and am having problems with the Gold plated solderless connector.
With the connector installed, if I tighten down the outer ring onto the radio antenna out, I get only static while tuned to NOAA weather. But if I loosen the outer ring two turns, I get excellent reception and can even hear farther NOAA channels clearly.
Here are the steps I took:
1. Strip the outer insulation down to the wire mesh.
2. Fold back the wire mesh.
3. Strip the center conductor so it's bare.
4. Slid outer ring onto the coax.
5. Screwed the coax into the center piece of the supplied connector.
6. Soldered the tip to the center conductor.
7. Screwed the outer ring to the center piece.
8. Inserted tip into radio antenna out.
9. Screwed outer ring onto radio antenna out.
10. Turned on radio, tuned to weather station. Static.
11. Loosened to check and re-tightened, and discovered the sound was perfect if the outer ring was loose by one or two turns.
Somehow the ring is causing interference and I'm not sure how to proceed or diagnose or fix.
Please let me know what else I can explain or share to help troubleshoot. I just can't imagine what may be happening to interfere with the signal when the ring is snugged down all the way, yet not cause any interference when loosened one or two turns.
Thank you!!
Thank you!!
