All,<br />I hope someone can help me out with a problem I am having with the lights on my 2003 EZ Loader trailer and my 2003 Honda Odyssey minivan. When I installed my Hidden Hitch receiver I also acquired their wiring harness, which included the required converter. As you may be aware, on many Japanese vehicles one must utilize a converter to allow the connection of the 5-wire auto system to the 4-wire trailer system. I utilized this wiring harness a few times with U Haul trailers without any problems over a period of several months earlier this year. The first time I hooked up the boat trailer to the harness it worked fine, but the second time the right-side lights wouldnt work. I took the trailer to the boat dealer and they hooked up a test light, which indicated that the signal for the right side (green wire) wasnt coming through the converter. The dealer indicated that these converters frequently malfunction and suggested I get a new one. Consequently, I ordered a new wiring harness/converter through Honda and installed it last week. The first time I connected it to the boat it worked fine; the next time it blew the fuse to my taillights as I was driving and then none of the trailer lights would work. I disconnected the wiring harness from the trailer, replaced the fuse in the car, and checked the power coming out of the converter. I found that, again, the right side (green wire) was getting no signal; the rest of the wires looked OK. I guess this means the converter now needs to be replaced again; obviously I need to determine the cause of this problem so that I do not continuously have to buy wiring harnesses and tear the back of the van apart to gain access to its wiring. Have I been unlucky to buy two malfunctioning converters/harnesses or could an issue with the trailer wiring (on the right side?) be the culprit? Any suggestions on what might be going on here? Thanks, Mike
