Very weird Yamaha issue
bcj.jones
I'm helping a buddy on his first boat. He purchased a super clean 1994 Champion 187 from a gentleman who swore it ran great. The engine is a 1994 Yamaha Pro V 150. It does run great, but we are getting a low oil warning light on the dash anytime we try to get on plane. This boat is equipped with the Yamaha digital tach. When the problem occurs, the green circle, the yellow oil can, and the red circle all start flashing, the warning chime turns on and the engine goes into reduced power mode. Once back at idle, all resets and its normal. Rinse and repeat. We've also starting getting an intermittent chirp from the chime at idle that sounds like morse code. I've done quite a bit of testing, so bare with me, but I'll explain all what I know.
Both oil tanks are completely full when this happens. I've ohm tested both the remote tank and main tank sensors. They both ohm perfectly fine in each position and the system operates as designed. Oil pump turns off when the blue/white wire is grounded, oil pump turns on when the blue/green wire is ground and the warning lights come on along with the chime when the blue/red wire is grounded. We even tried two known good sensors. Still the same issue. When the oil pump is commanded to come on, it pumps oil into the reservoir at a good rate. Again, the oil reservoir never goes low and the automatic oil system is working as designed. I can even disconnect both sensors and the warning chime still comes on under the same conditions. The gauge doesn't flash, but that's only because the sensors are unplugged. I know the engine is not overheating. We installed a new water pump, thermostat and poppet valve. I also brought my infrared heat gun out and it's within temp. Plus, the overheat light is the only one not coming on the dash. I checked the temp sensors, just to verify operation, by connecting both wires together and the circuit works. The overheat light comes on the tach and the alarm chimes. I've back probed the main oil sensor and wiggle wires and I cannot recreate the problem in the driveway or at idle. It ONLY happens when under acceleration. Sometimes at 3000 rpms, sometimes 4500 rpm, sometimes 2000 rpm. Very random, which is why it's been so hard to diagnose. I thought that maybe the float on the main reservoir was getting stuck under acceleration, so I zip tied it into the full position and tried again. Same thing happened.
I have even grounded out the green/red wire going to the tachometer and that will cause all three of the same warning lights to flash on the gauge, but it does not turn the warning chime on. The only time I can recreate the issue in the driveway while testing is if the CDI box thinks the main oil reservoir is low. I can do this by either just pulling out the sensor and manually lowering the float to empty, or if I supply ground directly onto the blue/red wire going into the CDI box. I know that these engines have a tilt/trim sensor that plays into the circuit but I believe it's only function is to turn the pump off if the motor is trimmed up too high. I don't think it has any way of turning the warning lights on? I mean, of course, unless it was not allowing the remote pump to come on, but that isn't the case with ours. I know the manual pump override switch is part of that circuit as well, but I don't believe it would have any way to cause a false alarm either?
Is this just a bad CDI box that doesn't like the vibration of the engine?? Or am I missing something? Maybe the stator or rectifier overcharging? If so, I would think more than just the low oil system would be malfunctioning. I could believe it was a chaffed wire, if I was only getting a short on the wiring harness to the gauge. But for the gauge to flash, and the warning chime to come on, I would have to have a short to ground on both the two pin (green, green/red) harness and the main 10 pin harness that has the pink warning chime signal wire in it. Possible, yes, but very unlikely. Wiggling wires hasn't worked so far. I'm lost!!
boscoe99
Weird only to those that do not yet know.
What you are seeing is indicative of low voltage to the CDI unit.
bcj.jones
Meaning the Stator is going bad? Or what else would cause low voltage to the CDI? I bought a DVA I can test the stator with. I know this isn't the best indication, but the gauge reads 14.8 volts while under acceleration. Also curious, why would low voltage to the CDI only cause the low oil warning lights and chime to come on? I would think other stuff would act funny.
bcj.jones
Come to think of it, the Speedometer sometimes flickers too.
bcj.jones
Also, wouldn't low voltage to the CDI cause running issues as well? Misfires etc. I'm not questioning what you're saying at all. Just trying to understand it.
boscoe99
The stator has different functions. Coils to charge capacitors in the CDI unit, coils to fire the ignition coils/spark plugs and coils to charge a battery.
The coils for ignition can be working just fine (motor operates normally) while the coils that charge the battery are not. Or both coils can be doing their job, but battery voltage is not getting to the CDI unit. That is when what you are experiencing can be happening.
There is a yellow wire that delivers battery voltage to the CDI unit. If battery voltage gets low on that wire, at the CDI unit, then the alarm that you are describing may happen.
99yam40
I wonder what the CDI is doing with the 12V DC from battery or lighting coil?
I know small 2 stroke motors do not need the battery voltage to run
boscoe99
Good question. Wish I knew but Yamaha is very vague as to the theory of operation with respect to their systems.
My guess is that it is to power the five volt circuit for the three wire trim sensor and other components that utilize five volts.
bcj.jones
Gotcha. So in theory, I could tap into just the yellow, charge wire, to the CDI unit and see if I'm loosing voltage on acceleration? Maybe best to just run the entire test on the Stator with a DVA? Also, where did you get that diagram? Worlds better than anything I've been able to find.
Yes sir, I've posted it in multiple places. It has me stumped and I was hoping someone could point me in the right direction.
boscoe99
I am thinking that I would disconnect the CDI connector and inspect the terminals, particularly those for the yellow wire.
Maybe then get a 12 volt incandescent bulb that has a current flow of about 5 amps when powered by a battery. Connect the bulb to the yellow wire on the engine harness side of the connector and to a known ground. Turn the key on. The bulb should illuminate brightly. Then measure for voltage drop at the bulb. Should be same or close to the same as the battery voltage.
bcj.jones
Funny thing, I mentioned doing something similar on a different circuit to my buddy but we never did it. I will definitely try that. Just to further understand the logic, why would the low voltage on the yellow wire only/mainly occur under acceleration? Is there a system built into the CDI that expects to see a certain voltage at a certain RPM? I was initially thinking maybe a voltage spike as the stator starts to charge more, but low voltage makes sense as well.
boscoe99
Posted below is what Yamaha has to say. That is all I have ever heard from them about this problem. Again, they offer no theory of operation as to what should be happening and when, and what happens if and when things don't go according to Hoyle. Millions of things in life that I have to accept for the way they are, without me understanding all that is going on.
For all that I know you might have an internal failure within the CDI unit.
bcj.jones
Good point! My brain always wants to know the "why" but there's a lot in life that just doesn't give us those answers.
Does Yamaha have an open questionnaire or do you just have access to some kind of Yamaha technician system?
bcj.jones
Weirdly enough it ended up being a loose fuse on the 12v power wire from the starter to the ignition switch/accessories. I was able to grab the fuse holder and wiggle it. When I did the low oil lights came on and the buzzer would sound. What's strange is I would think a loose connection there would cause the gauges to flicker on and off as it's the main power source for the system. Even more weird is it has no direct wiring or correlation to the low oil system, but it's the only system that would indicate an issue. I spend all my time on the oil system itself. Probably the most unusual problem I've ever ran into. Being that it had no direct correlation, and the gauges were not turning on and off, I would have never thought to look there initially. We wired in a new fuse holder and it works great now!
