1992offshore
- Mar 18, 2014
- 16
Good evening fellows, I replaced my impeller and gaskets with oem quiksilver parts, I have 2 questions. My pisser is very hot and it takes about 30 seconds to get the water, I also replaced the thermostats. It gets to 180- 190 while running in the water. The other questions maybe silly but is driving me nuts, I found something called connector assembly ( part # 85822A10 ) is a flexible tube with a closed end barb fitting next to the shaft,when I replaced my impeller. What does it do ? And does it need to be connected somewhere. Thank you in advance for your answers
