Re: Venturi Locating Tool
It's a good idea to have the tool in order to have the venturi aligned perfectly with the cylinder divider vane below the carburetor, however scribing a mark around the venturi sealing surface before you remove it usually gives you a near perfect method of replacing it.
Thousands of parts in my remaining stock. Not able to list them all. Let me know what you need and I'll look it up for you.
