Re: Venting I/O engine compartment necessary after towing?
That said, my boat has an electrically raised engine hatch and I'm not about to operate it before running the blower.
hum, well mines a manual dog house. complete with a bungee cord holding it in place. i only open mine on the fisrt start of the day after launching, after the blower. gotta have me a sniff......
In addition to running the blower, it's always a good idea to put your face right in the blower's output and take a nice long sniff.
i do that too............but,
Leaving the hatch closed also can help ensure the gas fumes are removed in the off chance the inlet hose has fallen off the blower.
the vapors are in the bottom of the bilge. most blowers are just under the deck, up high.......i don't know that it'd get enough flow to bring the vapors up from the bottom...... opening the hatch may lead to the discovery of the disconnected bilge blower hose. + if hatchs open after fueling helps rid those areas of possible fumes. it seems it'd hold true for the bilge too.....just my thoughts anyways...
i got my statement reguading open or closed hatchs while fueling from chapmans.........the question is, is one way better or another, not nessesarily while fueling....i don't know. mine is usually closed too...but for which is better. i aint gonna disagree with chapmans...
I'll be dumping it in out of cans most of the time anyway.
i use 5 gal cans too...... i usally make a bigger mess than if i'd go to the pump.......
