bob johnson
- Feb 25, 2009
- 4,306
how far INTO the fuel tank does the vent tube NEED to go or SHOULD go?
I have seen most , are just open tubes...on one tank I cut open it was welded into the tank on one end and ran the full length of the tank on the inside!!! up against the top of the tank. I have seen other tanks where is is little more than a hole in the top of the tank...with NO protrusion INTO the tank...
I have also see new vent tubes being sold that screw into a fitting on the top of the tank and protrude DOWN several inches..wonder how that can work.... I am THINKING the vent tub should be the highest part of the tank or the spot that fills last.....
bob.
bob.
