I am new to inboards, never had a marine transmission so I need help troubleshooting why my Borg Warner VelvetDrive is leaking transmission fluid from the dipstick. It will continue leaking until it is so low that it will not shift into gear.
I already replaced the vent, but that had no impact.
I purchased the boat with this problem and do not know the history of transmission.
Also, there appears to be a temperature sensor on the transmission but it is not connected to any gauges, will that use the same type of temp gauge as engine?
