Divecaptchris
- Jan 30, 2009
- 143
I just replaced the motor in my 1983 Carver mariner, it has twin 350's with Borg & warner Velvet drive tranys, to Walther V-Drives. After i installed the new motor and got it running i tested forward and reverse quickly with no issues, after re torque and some time i ran it again and then put it in forward for about 5 min, when i tried to take it out of forward it was still in gear at the neutral pos, and did not change until i hit the reverse pos where it stalled the motor, after checking fluid levels i tried it again a few times then it finally came back to neutral, however now i have no forward, reverse is fine, u can feel it start to go into forward, the RPM's change a bit then come right back up and does not go into gear, the fluid levels are fine and did not look milky. any help would be appreciated, Thanks
