QC
- Mar 22, 2005
- 22,783
1:1 tranny, fresh rebuild by amateur (no, not me, better than that) . . .
I am running on a stand in my garage (350 PCM Engine). If I move the selector to reverse, the engine lugs and wants to die, it does turn the correct direction. I can keep her running with some throttle, but seems like more load than there would be with a prop in gear.
If I move to neutral or forward, no change in engine load between the two, and I don't need any throttle to keep her running from the 700ish idle speed I am using. I cannot get the output flange to stop spinning in neutral with pretty strong applied force. I am using a 1 x 1 wedged/levered onto the side of the spinning flange and the wood starts to smoke and the flange won't stop. Seems like it is in forward gear with selector in neutral.
I believe I confirmed that I could get it to act kind of right in all three places properly before I started running her, but I can't remember how I did that. Maybe at crank speed, but I can't duplicate that now . . .
Oh, I also get a slight screech/squeal when the RPM drops to the point of almost stalling and then I catch it with the throttle. Seems to happen in all gear positions though, so might be unrelated . . .
I do have a Service manual and it sounds like either a control valve issue, too tight of a pack clearance or a warped clutch plate. Any ideas before I tear into her?
