CHEVYJEFF
- Apr 10, 2005
- 38
In the quest to figure out why my boat has hard starts when hot, I am confident its flooding when sitting due to gas smell. Since doing a massive search of this site and others. I have concluded that either my motor is experiencing vapor lock, a leaking well plug or a clogged tank vent. Here are my questions:<br /><br />1. How can I rule out vapor lock? I was thinking of insulating the metal fuel lines or putting a wet rag out of the cooler on the lines as a test next time I turn the boat off and create the hard start scenario.<br /><br />2. If gas is seen dripping down can I realease the gas filler cap and if it stops can I conlude the its a clogged tank vent?<br /><br />3. How can I determine if the well plugs are leaking down. Can they be seen from topside or will carb have to taken off pressurized and then tested.<br /><br />I have rebuilt the carb. checked and rechecked the float level, and drop per my mercruiser service manual and there are no visable leaks and I can shake the float and no gas is eveident inside. the boat runs great and starts cold just fine. I have also verified choke is working correctly<br /><br /><br />My specs.<br />1997 regal lsr 2100<br />5.7 mercruiser 210 hp 2 bbl mercarb<br />alpha one gen 2
