value of '93 Johnson 40hp VRO
jasper60103
Any idea what these go for?
Beautiful motor with electric start and remote.
The motor was boat tested and in very good running condition.
The seller, a hobby mechanic says he will bypass the VRO.
tashasdaddy
Re: value of '93 Johnson 40hp VRO
does it have trim n tilt, or just tilt assist. i have the same motor. the market is down, but they were around $1,000 with tilt assist, and 1,200 with trim n tilt.
jasper60103
yea, he said $1200 for Tilt & Trim, and he would install on my boat and lake test with me.
edit: with a foot controller for Tilt & Trim as well.
thanks.
jasper60103
Hey TD,
so how has the motor performed for you? Any problems?
thanks,
jasper
tashasdaddy
i bought this motor used 2 years ago, all i have done is change the plugs. it is the most dependable motor i own.
cantankorustr-6
1979 Larson Manta 5500
Does anyone have information (good or bad), on a 1979 Larson Manta 5500 17ft, I/O 170 hr Mercruiser?
jasper60103
Hey TD,
hope you don't mind me asking, but
what kind/size of boat are you pushing with it?
thanks,
jasper
tashasdaddy
this 14'6 glass fisherman. the boat is rated for a 65, but i don't want to be in it with a 65hp. i have since taken it off the market.
Backcountry
Those values seem about right. I looked at a '92 Alumacraft Crappie Pro last year with I believe the same motor, one year older. They were asking 2995 for the rig and got full price.
jasper60103
Oh, Ok. I remember you posting about the price on this one. Nice setup IMO.
I'm still trying to decide on the motor. If I keep my little 25hp. If any problems ever arise, I can easily swap it and keep on fishing. That won't be so easy to do if I go with a 40hp with T&T. I thought about getting a 35hp motor and just keep the 25hp as backup (but run it occasionally).
I guess part of me wants to keep a simple setup. Light motor, rope start, manual tilt, no battery, etc.
But my boat would benefit from the extra power the 40hp provides. 400lb. boat, plus added weight from plywood flooring. It's rated up to a 50hp.
Anywho, thanks for your input and allowing me to ramble on.
jasper
tashasdaddy
i actually had an 1988 50 on that boat, before the 93 40. i can tell very little difference between the 2 motors being on it. i've been helping a local member with is 88 25hp, found it harder to work on the the newer 40's and 50's. they are the same block.
ED21
Master Chief Petty Officer
I have an '89 40 w/ t&t, no vro, tiller model for about 5 years & so far it's been a terrific motor. I got mine from a relative & payed less than market value, so I can't help you there.
It starts fairly easily once you figure out the system as described on iboats often. It's easy on gas & runs strong. The only minor complaint is that it idles on the rougher side when crabbing, but it doesn't stall and has always started.
jasper60103
I plan to close the deal tomorrow on the 40hp. The seller is a hobby mechanic and he sold me the 25hp a month or so ago. He will credit me the full price paid for the 25hp.
I think I'll be better off with more ponies and newer motor.
edit: not to mention added perks like electric start, tilt&trim.
Thanks for you input.
jasper
tashasdaddy
you will be much happier with the set up. happy boating. let us know how it performs.
